cuda rallye dash questions
0ld school
va.beach, va
i'm restoring my cudas rallye dash. can someone tell me which way is up for the wiper swich? i see it can go both ways. also, what do you use to hold the wiper and headlight knobs on. thanks
wiper sw is notched as is the bezel knob should turn left (off) to right (on). all knobs just push on and are also notched
Zackly what Rocky said. The wiper knob may have a spring clip inside that helps hold it on. The headlight knob is part of the "shaft" and there is a pushbutton on the bottom of the switch to install/remove the knob/shaft
Wiper switch and headlight switch are positioned with their harness connections on top.
The knob of the wiper switch could have had a small allen set screw ( depends on year model ) . Headlight switch is a pulled operation so that is a knob and stem assembly that shouldn't be seperated.
