Cope
Fusing with fire
I have no idea but remember, this is a Ca. Truck. Smog is an issue.
I believe it became obvious when the dowl pin fell out and as a result gets lodged up in the rotating cam, pump gears and causes much damage. Just sayingYeah but it really became obvious when people started playing with the fuel ramp plates in the p7100 series pumps of the 94-98.5 12 Valves.
The 04 has a Bosch Common rail pump. The p7100 was used only on 12 valves from 94-98.5. They can be swapped on to the later engines but it’s really not worth it unless you just have to have mechanical injection.is it a pt pump or p700 inline pump? if you want more power send pump and injectors to primco in lampassas tx there the best and affordable! then turn up rail pressure 20ish lbs, then step up the turbo,..retard cam a few degrees an shell pull stumps by god!!
You have a Bosch CP3 pump. You would know it if you had a P7100 as it’s mechanical injection and anyone going thru that expensive set up to swap it, isn’t just gonna do it without playing with the fuel and timing of it, IE it ain’t passing CA smog with a P pump conversion.I have no idea but remember, this is a Ca. Truck. Smog is an issue.
No such thing as a PT pump or a p700.is it a pt pump or p700 inline pump? if you want more power send pump and injectors to primco in lampassas tx there the best and affordable! then turn up rail pressure 20ish lbs, then step up the turbo,..retard cam a few degrees an shell pull stumps by god!!
True but what I meant was the more people started messing with them aftermarket wise, it definitely became more well knownI believe it became obvious when the dowl pin fell out and as a result gets lodged up in the rotating cam, pump gears and causes much damage. Just saying
He has a common rail, all he needs is EFI Live that Quadzilla used to sell or a Smarty CR, or a TST PowerMaxCR, or similar, he can gain 100-180 hp and double that in torque and simply remove the thing when he goes in for emissions and they’ll never know. These are all programmers that play with injection timing, pulse and fuel flow rates. The SmartyCR would be best as it’s basically a hand held scanner that takes the factory code out of the ECM, puts in an aftermarket tune. Takes less than 30 seconds, no wiring no evidence etc. then it can be switched back in the same time and no one ever knows.it can be tuned for more power and not blow black smoke,..black smoke is un burnt fuel, thats not making more power! idk if it pass smog test but it can burn clean and still put out good power! i ant talking bout pulling truck power, just 50 to 75 more hp and couple hundred more rpms!
Only injection pumps used on B series from 1989 to present are:
The VE pump, 89-93
The P7100 in-line pump 94-98.5 12 valves
The infamous VP44 rotary 98.5-2002
The CP3 common rail 2003-2019; (switched back from the CP4 to the CP3 starting 2021-present)
The CP4 common rail pump, 2019-2020
Yeah we’ve got an early n14 big cam 1 in our grain truck, all mechanical but the pump on that thing is massiveView attachment 1716083640
put a lot of miles on a 6bt but never got to work on one, im much more knowledgeable on big cam 1,2,or 3's!! thay all come with the PT (pressure-time) pumps, all mechanical! wish some body come out with one them programmable deals you speak of for a cummins N14! could sale thousands of them, same for one for the detroit 60 series too!!
mechanical N14s are rare and highly salt after, got the steel top pistons and you can make alot more power before melting it down!! pull cap off back of pump see what button in it and drop it to a button 5 numbers smaller, a green and yellow spring and as many rpm shimms as you brave enuff for,..youll have fasted hill pullin'est ol grain truck around!Yeah we’ve got an early n14 big cam 1 in our grain truck, all mechanical but the pump on that thing is massive
If it were mine I would, dad won’t let me. He’s a purist on everything. Drives me batshit crazymechanical N14s are rare and highly salt after, got the steel top pistons and you can make alot more power before melting it down!! pull cap off back of pump see what button in it and drop it to a button 5 numbers smaller, a green and yellow spring and as many rpm shimms as you brave enuff for,..youll have fasted hill pullin'est ol grain truck around!
my dad would turn one up twice as much as anybody else and send it! his last truck had stainless stacks that were blued from how hot he had it, 2100 rpm redline he turn it 2800! g'pa was like your dad,..leave it set where cummins set it! dad get 100,000 on a rebuild, g'pa put a million on his last truck never went lower than valve covers to adjust rockers! put that many miles on the factory clutch too, when thay pulled it the disc were so thin the rivet heads were wore off, kenworth put new clutch in free, said any man put that many miles on one shouldnt havt to pay for itIf it were mine I would, dad won’t let me. He’s a purist on everything. Drives me batshit crazy
Finally someone who gets it. Rolling coal............Look at me everyone!black smoke is un burnt fuel, thats not making more power
Not that I disagree (I don’t) but I have a funny story about that.Finally someone who gets it. Rolling coal............Look at me everyone!![]()
Some smoke when making big power on a diesel is unavoidable. Especially with big turbos.I love my programmer its the race me one, mine only rolls coal when I get on it but after that normal exhaust and for a 3500 dually its kinda scarey how fast this thing goes, and I only use street and performance tune, don't dare run the race tune. I figure on performance I'm over 1000ft lbs of torque since my base is 850 ft lbs on mine.
My best numbers turned on stock turbo(ish, it was modified but stock housing) 467 hp at 2100 and 1545 ft lbs at 1800 at the rear wheels. I’d hit 50 psi on boost nearly instantly. I sheered the hub out of south bend double disc instantly with the Comp box . That box hits HARD of throttle.I love my programmer its the race me one, mine only rolls coal when I get on it but after that normal exhaust and for a 3500 dually its kinda scarey how fast this thing goes, and I only use street and performance tune, don't dare run the race tune. I figure on performance I'm over 1000ft lbs of torque since my base is 850 ft lbs on mine.
totally off topic, but do you know of a controller you could suggest to get better mileage and more power out of a '17 5.7 hemi ?He has a common rail, all he needs is EFI Live that Quadzilla used to sell or a Smarty CR, or a TST PowerMaxCR, or similar, he can gain 100-180 hp and double that in torque and simply remove the thing when he goes in for emissions and they’ll never know. These are all programmers that play with injection timing, pulse and fuel flow rates. The SmartyCR would be best as it’s basically a hand held scanner that takes the factory code out of the ECM, puts in an aftermarket tune. Takes less than 30 seconds, no wiring no evidence etc. then it can be switched back in the same time and no one ever knows.
Not really into that nearly as much but I have heard very good things about the Diablo Sport Tuners.totally off topic, but do you know of a controller you could suggest to get better mileage and more power out of a '17 5.7 hemi ?
(i understand the gains wont be as earthshattering as on a turbo engine)
What kind of mileage are you getting? My wife has an SRT Durango with the hemi and AWD, fully loaded. Thing is a tank but getting 22.8 average driving county roads. We got almost 26 mpg out of it with an average speed of 82 mph going to Florida last may
Mines all stock except for full deleted and the tuner with a better air filter. Would be fun to see what my truck puts down I'm only guessing over 1000 ft lbsMy best numbers turned on stock turbo(ish, it was modified but stock housing) 467 hp at 2100 and 1545 ft lbs at 1800 at the rear wheels. I’d hit 50 psi on boost nearly instantly. I sheered the hub out of south bend double disc instantly with the Comp box . That box hits HARD of throttle.
If I’d just stepped up to even a 60 mm turbo , I’d been pushing 700 easy. I had the fuel to support it just not the volume of air
