Michael Harrington
There is a thread from early 2025 showing either the LA mounting holes drilled in the wrong location OR.....The intake ports cast in the wrong location. I have a pair of said heads. It was asked of me to install them on a block THEN place the manifold on and see which is the culprit (As opposed to simply placing a gasket on a head sitting on a work bench.) I recently obtained a short block in my garage and finally was able to do this. The mounting holes match up correctly- HOWEVER, Shining a light down a tunnel ram reveals the ports of the intake manifold have a significant mismatch to the ports in the Chinese head.
