68 Dart post. Narrowing a big car rear end to fit. If you had a choice for width would it be exact a body width (accounting for b body brake diff) or narrower for wheel choices. Also using 1\2" offset kit. Not really planning on cutting car. ?
save some money and cut it to A-body axle length so you can use those. If custom axles and 1/2 offset, Id go maybe 2 inch shorter on each side.
So for $300 you can get any length you need new. I was speaking about saving money by buying used A-body axles in a 5 on 4 pattern and making a stock A-body 8.75. If guy wanted to use B-body brakes (did I read that right?) custom wheels , by all means go with the 5 on 4.5 axles cut to length, then he'll have 2 bolt patterns on his 68 car minus BBP disk upgrade.DoctorDiff sells custom length axles for $5 more than A-body length axles, so it’s not really much money you’re saving.
Thanks guys. Yes, I'm going to run bbp discs up front. I've done some more research and I think i see now what I need. The answers in post #2 is my dilemma but also what I needed to hear. So I think I will have rear built to stock width. I'm going to run 'cop' wheels with drag radials when stick shift drag racing and 17x8 5.25 bs wheel with spacer TBD for everyday handling road wheels.
Ive read some of your info from other threads and if I can run 245/45/17 all the way around I will start there. I do have two TT 17x8 4.75 bs with that size tire on them now and they measure almost perfect on the back but if they are going to tear up the front fender I will look to the bigger back space. It does prove the small spacer for the back.
Move springs to frame rails if you want some bigboy tires.............
pending your wants/needs.
