Okay, I'll remove the regulator completely.Reg wont flow the air. If its running out of air before compressor kicks in, there is a restriction in your air supply. Not the couplers either. I run an ingersoll da about 3 years old and it works fine. No regulator.
Even with 3/8” air hose the barb in the hose is your choke point, so high flow will make little difference.
