dustinmoran91
Like it says my dad walked out on us today and so my stuff has to go to make bills get paid. All stuff is located in muskogee oklahoma 74403
I have 78 model 440 that is complete and appears in good shape, heads are off and walls still have crosshatching, bearings look good aswell. Has 452 heads and stock intake, no water pump housing or distributor. Asking $500 and ill throw in a holley 750 vacuum secondary carb that could use a kit.
Also have my 70 duster you can buy amd part out as it is pretty much a race car but not a track legal one. I was building it to go fast on the street and thats it. Has a narrowed 8.8 with 3.73 limited slip and disk brakes, 727 that i was told is good but not certain, has a 318 with factory flat tops, new bearings and rings, magnum heads, howards cam with .501 lift [email protected] and 276 advertised 108 LSA and 104 intake centerline. Has a holley 650 on it amd a mopar blue box. Had it running for about 10 minutes to do the cam break in but disnt get to finish. Needs a different intake because that one was leaking really bad and messing with the break in. Has an off brand holley black pump thats brand new. Has all new front end including bushings, bearings, ball joints, radiator, aslo has 29/10.5/15 slicks on the back. All aluminum floor and a competition engineering roll bar, also has new brake lines and fuel lines, new master cylinder. This thing is far from pretty or perfect but i just wanted to go fast so thats all i was worried about. Looking for $2000 just because i have that in parts probably. Make me an offer and ill take it. Will post pics when i get a chance
