I used some body filler to smooth out my welds in the floor of the car, top and bottom. I wasn't going for a perfectly smooth finish, just trying to dress things up so the welds wouldn't be so obvious. This was especially true of the butt welds, but some of plug welds had low spots that I filled as well.
The repair inside the trunk (passenger side) was not my best work, but after the filler, it looks fine. I decided at the last minute to add some filler to the driver's side for symmetry. There were some low spots there and I also filled in the spot welds so now neither side has them.
There were a couple of dents in the spare tire well that I dollied out and filled top and bottom. The one at the back was tricky since it was in the complex area around the drain plug.
I didn't get pictures of everything. I filled along the butt welds on the inside of the rear quarters. I also used a tiny bit of filler on my repairs to the bottom of the trunk extensions. My repair to the front fender skirt near the battery tray also got the treatment.
I found quite a few holes in the body where the factory welders burned though the metal. The factory plugged these holes with seam sealer. I welded them shut and grinded them smooth.
I did a lot of dry sanding on the epoxy primer in order to provide a key for the second coat to adhere to. I sanded quite a bit more than necessary just to catch the overspray. This would be a lot easier if I was fast enough to get all this done within the recoat window of the epoxy primer (only 7 days). As it is, I will need to sand most of it again just prior to the top coat. At that time all filler should be encapsulated in epoxy primer so I can wet sand instead of dry sanding.
I may be going overboard a bit, but it really didn't take that long and I think it made a big difference. An expert will still be able to find my repairs, but he'll have to look pretty close. I think I'm finally finished with metal work. Now I can move onto the parts of the car that actually show.
