Please take this in the LOL in which it's intended.
Unless you have problems like Doug, or an arthritic old guy like me, you don't have nothin' ta ***** about. LOL
Takes me about 10 times longer to do somthin' nowadays because I have to THINK "what is the easiest way, and what tools will help that?"
Working under the dash means taking the time to pull a/ both front seats.
If I didn't have a chassis hoist I wouldn't be able to do ANYthing on my car
I use power tools whenever possible, even for screws
Headers---get creative. Mine have a mix of "header" bolts, standard head cap screws, and allen for at least a couple for no 5 and 7. For one of the rear bolts, I have a "special bent" allen wrench to reach it.
Steering coupler--you need a Great Big Punch. Having a lathe is nice, but you don't need one. I took a chunk of scrap rod, drilled and tapped the end for (5/16?) and screwed a grade 8 bolt in there and cut the head off. This makes something you can get AHOLD of and bang at.
I will admit to having troubles with upper arms--junked out a Demon and a Duster. One set came right out, third upper took awhile, last one I damn near gave up on. The car was a junker, so I DID do damage to the front frame member to save that precious A arm
STRAPS. I have several tie down and ratchet straps which are indispensible for pulling/ installing a rear axle or springs, or tying up the TF when pulling the engine alone.
4 speed? In the 70's I had the 4 speed in/ out of my 69 RR a few times, a VERY long story. Used a huge hydraulic floor jack we had at the RADAR site, and was able to balance the gearbox on the jack and "slip" it right in there.
ONE KEY to getting a gearbox in is to make at least one alignment stud screwed into the bell, and either put the box in reverse + any forward gear, or put the box in any gear with a spare yoke on the end. This allows you to get the splines lined up.
WORST THING I have ever "done" --and it's not done yet-- is replacing the cam sensor in the pushrod V6 in my 98 Ranger. You have to tear half the top of the engine down to get to it, and THEN you can't see it, you have to work by "feel."
And so here we are, 64, arthritic, it's snowy, freezy, cold, and my fingers hurt. So for me, it's not "Damn that was a pain," it's "Damn this IS a pain!!"
