[FOR SALE] Dana 60 Rearend $1000
littleredcoffin
keene nh
Back side of each axle tube flange to opposite axle tube flange on the inside is aprox 46-47 inches.Spring perch center hole to center hole is 36 inches...Has correct pinion snubber,.Comes with very clean backing plates and New with some surface rust multi lug 10 inch brake drums...The gears set is 4.10,,,The ring gear has a 41-10 stamped into it.Internals are clean.Not dirty, nor does it smell burnt.Eveything looks clean.Yoke turns the gear set fine..The gear set turns firm and smoothly and is not full of back lash.Axles need bearing.They have rust from sitting.The axles where not in it for some time..There is a "60" on the housing to the side of the cover..Please dont hit me with 50 questions.I was told it came out of a tubbed Dart.I know no history on this rearend.I have taken honest pictures.I will not ship this..I have priced this to sell quickly and not sit collecting dust.I do not believe this price can be beaten..$1000 firm.Keene NH
One question, What is the bolt pattern of axles please? Not sure if they are 4 1/2 or 4 3/4 chevy?
