matthon
- Joined
- Aug 29, 2008
- Messages
- 3,855
- Reaction score
- 2,947
Searched, found same issue, but solutions don't seam to apply.
Upgraded to bbp axles, housing completely cleaned, center section sealed up with new gasket, vent cleaned up inside and out and resealed, used a little green tube gear oil rtv on both.
Rear was filled on a lift just below the fill hole.
Swapping shocks this week, noticed it's been leaking enough to cover the housing and sway bar, but not enough to drip.
Everything is sealed up, no leaks, except the top of the vent.
I see some put a hose on it and route it up to the shock mounts.
I don't really want to do that as I have other cars that don't have this issue, trying to figure out what's up?
