jasonmrenda
- Joined
- May 13, 2009
- Messages
- 271
- Reaction score
- 1
i dont know if i am just doing something wrong but i spent 2 plus hours trying all varo\ious ways to get the transmission linkage set up properly and i cant get it.
the car starts in neutral and park and not in any other gear so i know the safety switch is working right.
so to refresh, the car was a 67 /6 with auto transmission console shift. i replaced the engine and transmission with a 76 318 auto that was a column shifter. so i swapped the lever that attaches to the transmission (to which the shifter linkage attaches) from the 67 to the 76. didnt change any other parts of the linkage. so basically the 318 transmission has the lever from the /6.
i vaguely recall that the linkage on the /6 shifter went "up and down" and then connected to the linkage to the trans. now the link from the shift goes east-west through the coupler to the trans linkage. i apologize for the terrible wording.
the lever on the transmission goes into all gears smoothly and with a good "chunk" sound so i know the gears are all engaging. the shifter itself clicks in all the detents also and will navigate through all gears when hooked to the trans linkage. the problem is i still get no reverse. i know the trans goes into reverse when i move the lever on the trans manually. but the shifter is not actuating reverse. it almost feels like the linkage does not enough lever-action to push and pull the gears into place in the tranny?
