Hay.....that tool looks like it's been used..........ALOT. LOL
apologies for pic, i took two one of bushes but stoopid pc not recognise, will re do, reason i dont think will fit is this, i cut the old rubber ones out of a arm, what im looking at on A arm is a tube which is part of A arm<or does this need pressing out too:violent1:>, now holding the new bush with metal sleeve cannot see even with vice /press it going in........the rubber on inside of new bush however does but this shouldnt be right cutting metal sleve and taking rubber out, apologies rayer:if this sounds real spastic of me!Such a wonderful pic of the new bushings you took. NOT. From the looks of it, those are the type bushings that reuse the old sleeves.
"You use this tool to remove and install upper control arm bushings.
Or you can be creative with a hydraulic press, and use sockets to brace, and press out the bushings, a piece of pipe, anything that you can think of to get the job done.
Best advice going. See if you can rent one from the local rent-all or Dodge dealer.
