Dart Interchange?
scooby199518
Member
Grand Junction,Co
Does any one know if i have to change the whole front clip to change a 72 dart to a 70 and is there anything else i would have to swap?
Thanks for any help!
Steven
Did this a couple yrs back on 73 dart, changed to a 70-71 dart front clip, just a note about 72 dart/demon front clip , the front fender extentions{nosepiece] is different in depth than 70-71 in the grill/bezal/eyebrow area and you almost have to put them side by side to see the difference, one is deeper than the other in depth and wont install properly, so must be matched to work--for example if u use 70-71 grill set up then u will need nosepiece or fender x-tentions from 70-71, if u use 72 grille then u will need to use 72 only x-tentions[nosepiece] done been there and really frustrating, ucan see difference by comparing 70-71 eyebrows with the 72s. otherwise its a very worthwhile and better looking change, why Dodge did this subtile change is a mystery for they look the same on 1st glance. GOODLUCK
