Dartin for Divorce
How much do you want to see leave your accounts?
(not how much you can afford, becuase usually you can afford more than you would want to spend.)
do what you want doc, but ask yourself; would your wife care about 200$ at a time, or one 10k plus another 5k plus another 1k?
:drama:
good luck on your decision. you'll most likely love it no matter what route you decide to go.
:drama:
My wife would prefer $0 spent lol
:drama:
you'd be very lucky if you only spent $200 at a time rebuilding a motor.
i meant the lumps of cash will be mostly much bigger than that :thumbsup:. the BPE 408 can be bought quite a bit less than 10k too, if you reuse some ancillaries from your old motor.
yeah of course but for me, a little at a time is always better than spending 5k for built motor all at once rather than spending 500 to 700 at a time doing it yourself.
Idk, i think it softens the blow of completely changing your car.
There's the guy that buys the totally restored done car.
There's the guy that pays the resto shop $80,000 over 2-3 years.
There's the guy that buys a $1000 project, builds it himself, $200 at a time, :rofl:over 20 years!
don't forget $1000 car + 10 years of upgrades = never "finished" and sold (at a loss) for a new project
Neil is right on the money DD. Upgrade the unibody, rear end, suspension, and brakes to handle what you intend to put in it. TBH my "fun car" 2007 mustang GT has a 300hp 4.6L V8 5 speed and 3.55s and it pretty freaking fast as it is. It will peg 140mph, and idles great. I dont need to go any faster than that. 500hp is a lot on the street especially without electronic nannys. I know hellkittys are like 700hp, but they also have the added benefits of yaw sensors, active suspensions ABS, and TCS which help Joe average to drive it like a pro. What I'm trying to say is 500 hp you may hit that mark, and many do, and then they dont enjoy driving the car as much.
Not trying to tell you how to build the car, but going to explain the nuts and bolts of the one I am building with/for my son. 69 barracuda coupe so basically a 108" wheelbase dart. 3200 lb car. We added subframe connectors, upgraded to big bolt pattern with cordoba big calipers and discs, ford explorer 8.8 with discs, and a hellwig 1&1/8" front sway bar. The usual polyurethane bushings all around etc.
Now to the drivetrain. It will be a 300hp warmed up 318. Yes a 318. Trans is a 42RH with lockup and O/D out of a V6 1992 Dakota. This trans has 3 mechanical forward gears like your 3 speed automatic so your stock floor shifter can be retained. The O/D and lockup are electric. I went 42RH which is A904 based for several reasons. 1 they can be built to handle up to 500hp so behind a 300hp engine it will be reliable. 2 they are smaller and lighter than the 46RH. And 3 the 1st gear gearing is lower than the 46RH to help a V6 truck pull a load from a standing start. Turn the lockup and O/D on above 55mph with a toggle switch, turn them off below 55mph with the same switch. The rear end gearing is 3.73 along with 25" tall tires on 15x7 chrysler steel rims.
Whats in gearing? A lot. With the 300hp, 3.73s, and low first gear gearing that the 42RH has, this things gonna be really quick in first thought 3rd gears, and a 300hp 318 will not be real cantankerous to run. At 75 mph on the highway with the lockup and O/D turned on and the RPMs will sit at about 2400 rpm. Best of both worlds, on a rock solid chassis with good brakes and mostly stock parts with enhancements and upgrades.
Again not telling you how to do your build. Just explaining our build, and showing you a different option you may not realize is out there. A lot of times, or dare I say most times, it's not all about just absolute horsepower, but about a carefully selected package of horsepower, gearing, suspension, brakes, and chassis. I have a long winded build thread. Not sure if you looked at it. 67/68/69 cuda dilemma. All the information is there on the 42RH install mockup, and soon the 318 buildup once the block is out of machine shop jail. I feel the combo of (lower levels) of HP which is easier to build, and with better idle and driving manners, along with the rest of the package will make for something that's fun to drive, and not a chore to drive.
Matt
The only part of my suspension that is not new is the rear springs... also have front and rear sways.
Transmission rebuilt last year, getting new tc and already have a new VB. Rear end rebuilt with new 5 x 4.5 BBP wheels, and will install rear discs.
I just need more power... more gear and more fun. That's always the problem, you always want more.
You know what I love about our Dental Doc???
He's one of us! He can't help himself - he has to tinker. Remember all time he spent on the brakes!!!
The guy knows almost every nut and bolt on his car.
It doesn't sound like he grew up on a farm, or with a father who showed him how to use all kinds of tools.
He just has the itch and has to scratch it. Go for Doc...build an engine from the block up, we'll help you along the way!!
he shouldn't have started with the tiny dental tools. ended up with tool envy and had to find something man sized to wrench on :lol:
I still hate my brakes! They suck!
#1 is E body guys
#2 is B body guys
#3 is A body guys
#4 is F body guys. Whats 4? The guys that hauls an F body project home and it breakes in half unloading off the trailer so they part it and add to the other 8 F bodies that did the same thing!:BangHead:
#1 is E body guys
#2 is B body guys
#3 is A body guys
I remember my grandpa bought a new F body, the dealer had to change the front fenders out when the car was two years old because they rusted out.
I got new window rollers... f this window, its impossible, I've tried every adjustment possible and this is as close as it is going to get...
Leave it for a few days and give it another try.
I had the same frustration with mine. After several attempts spread out over 2 weeks, I finally got it to where I like it.
I'll work on it this weekend, I've been kicking some butt at work this week though. Even though I had to... wait for it... rebleed my brakes :elmer:
I'm at a loss there is no freaking fluid anywhere and air keeps getting in the system. I'm ordering rear discs, new springs and then maybe a MC from Dr Diff.
I got a 360 short block for 200 bucks! I'm also getting a 489 case with 391s and sure grip for 500!
This car is going to be... fun! Have to start planning a stroker build... really just have to decide on what stroker kit and heads --> the "CC" part and also camshaft. Don't worry I'll start a "what camshaft" thread in the sb subforum lol :rofl:
