The instrument fuse is a "trick."
The headlight switch gets power from TWO sources
ONLY headlights are one source which is not fused. The headlight switch has a built in breaker
A SECOND power source TO the switch comes from the TAIL circuit fuse. This powers park, tail, and INSTRUMENT lights.
After power goes through the light switch, and through the dimmer control, it goes OUT to the instrument fuse
So in other words the tail circuit fuse must be good and that circuit working
The light switch must be in either park or headlight position
Only then will you get power to the instrument fuse.
And of course the fuse must be good.
