I ran into a similar problem. My 1968 Dodge Dart though had a broken prong on the back of the circuit board. One of the 5 prong connectors leads power to all of the instrument cluster lights. If this circuit board is broken or bad you need to get another.
One fuse doesn't have power on either side of it until the head light switch is pulled to at least the first click. Then the fuse would have power on both ends. Double check it. Hope this helps
Hey everyone, I'm having a problem with the left instrument lights not working, the right side of the instrument cluster lights do work... Any recommendations??
If that panel has 2 seperate boards, Problem could be a lack of ground to the right side board. The panel wont function properly while dangling from the harness connectors unless you attach a chassis ground wire.
