Dash pad removal, what's it take ?
the dash pad is help on by just a few screws and couple nuts. feel up under the dash into the back of the dash pad and you will find them
flexible hands and some painkillers after you get the five nuts off! YOur hands will get cut up!
Dash pad can be removed with Dash frame and window in. Dash frame can be removed with the window in...but it takes skill know how and I dont know how you put it back!
Most of the time you remove the window.
Aloha!
Remove the instrument panel and the glovebox linner.
The pad has 5 studs welded on it with 3/8" hex nuts. One centered ( defrost vents as guide ) then 12 inches left and right. The turned down ends of the pad have one sheetmetal screw with 1/4 " hex heads.
