TA head 69?
1955 kleinschnittger f25. Aluminum body. Windshield frame and a couple hard parts. Has a vin plate. Very, very rare car. Body weighs around 60 lbs.
Complete dc 100 volt junior dragster system minus battery. Came out of the 2013 nhra northwest jr dragster open winner. First electric junior dragster to win a wally. Set a nedra record at 8.68 @ 61 mph. All new wiring. Custom motor, controller. This is the drive train that started it all.
Was installed in a custom rear slicked, front Tony shifter cart 74 Johnson panther 35 snowmobile. Flipped hooking up and over during launch trials at 51% battery power before I put a wheelie bar on it. Ended up being unstable at high speeds. Very powerful. Very fast. Very dangerous on 3 wheels. Barn found the body and was going to build a 4 wheel roadster.
Has an energized contactor that runs off a separate battery to a lanyard switch. Probably saved my life!
See lightswitchracing.com for more info on the drive drain. You can turn it down. Have the charger also. Not pictured.
1650.00
1650.00
