I have a 94 360 magnum that is fresh.
I built it for my duster, but may put it in my truck 78 W-150 SWB standard cab 435 4-speed 3.55 gear 28" tires
I need to make a truck motor out of what I already have.
As the motor sets right now:
Std bore, Std stroke, KB 107 pistons bottom end balanced, I do not want do anything to the block, crank, rods.
OTB Eldebrock mag heads.
If I put everything right in the compression caculator I have 11.37 static and 10.17 dynaimic.
This is with a Comp XR280HR-10 cam.
.039 head gaskets.
This truck will be used for pulling trailers and heavy loads.
Low usage only about a tank of gas a month.
How can I get the compression down?
Or am I better off building another motor with about 9.1 static and just leaving this one alone.
RPM requirements are 600 rpm to 5000.
Would like to run on pump gas.
.039 head gaskets.
