So after installing rotor an dist cap and tightening ground back up, it seemed to fire right up? I've been following all the checks you guys have given me. I just checked the last one Inertia gave me an sure as sh-t after I shut it off fuel is trickling down. I did check the float level when I first installed the carb. Guess I'll have to readjust the float level. I'm not sure what's changed, I still have the fuel pressure set the same. Thanks again, with any luck I'll be taking it out tomorrow.
