T56MaxTorq
Took the duster out for a ride and some carb, kickdown linkage adjustments and noticed a LOT of smoke out of the passenger exhaust. I have headers and duals. Ran a compression check and #2 is 0-30 psi. Bubbles in the radiator. Pulled the valve cover and the intake roller rocker adjuster was gone..laying in the top of the head. Unsure if the cam is now flat. I put it all back together and wanted to check gross lift of the valve but my dial indicator only sweeps .20" Any other way to check to see if it's bad without taking off the intake? Maybe a mechanics ruler would at least see if I have .5" lift. Too dark and frustrated to work on it tonight. Any help would be appreciated.
