Just broke in this fresh build. I have one cylinder that has not fired yet. The spark plug looks like I just pulled it out of the box. I do know that the plug is firing. Did a leakdown test and it sounds like the exhaust valve is not sealing for reason. I know I will have to remove the head to see exactly what happened, but just curious until I get around to it. The cam from what I can tell is not wiped out. Both valves are opening and the adjustment has not changed. This engine has only about 30 minutes run time in the garage, that it.
What do you think happened?
