decodeing 273 from 1964 plymouth
Doctord
Germantown NY
Recently purchased an engine and transmission from a 1964 plymouth valiant, its a 273 4 barrel, with what i believe to be a 4 speed. im having a hard time decodeing the numbers from engine and transmission, the numbers i have gotten from the engine so far are 2806030-273-6. that is from the drivers side of the engine block behind the exhaust manifold. im trying to figure out what transmission i have, the only numbers i have found so far are, c-85639u which was on the passenger side of the transmission and c-95858-0 on the tail shaft, also on the passenger side, these are the only numbers i could find. any help would be greatly appreciated. i did the best i could to read the numbers considering the engine/transmission have been stored outside for the past 20 years.
For it to be a 1964 833 it will have a ball and trunion output shaft flange instead of a slip yoke. If the tailshaft does not have a bolt on driveshaft flange it is not a 1964/65 trans, unless someone has swapped out parts from a newer unit.
To tell a four speed from a 3 speed
3 speed has 2 shift rod mounts in a row
4 speed has 2 shift rod mounts in a row and a 3rd shift rod mount down low
The included link is an example of a 1965/66 and later four speed. I am not real sure on what year each engine stopped using the ball and trunion, but all 1964 models had them.
http://compare.ebay.com/like/190490367229?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
And here is some reading on the variation of the 833
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
All 273 blocks, 2 or 4 bbl will have the same casting number. The only way to tell a true Commando/Charger (4bbl) from a 2 bbl engine is by checking for the domed pistons. Basically the diffs. between a 2 bbl and 4 bbl 273 are : pistons, cam, carb, air cleaner, intake, valve covers, dual point dizzy. Everything else is the same, including head and block castings.
