Decoding A833 serial numbers
Slim Flipmin
Ham Lake, MN. USA
I found a tranny on CL. The seller doesn't know if it's a 4 speed or OD unit. It has a cast iron body. Anyone help me ID it? TIA
Can you get a clear photo of this entire pad so the numbers & letters are legible?
A dead give away for an O/D is a raised rib that runs in between the shift levers on the side cover.
That looks like the large bearing retainer, but the angle makes it really hard to tell.
