rklein383
- Joined
- Dec 2, 2005
- Messages
- 2,216
- Reaction score
- 1,817
I have installed my new Comp Cams High Energy camshaft. The instructions state that Comp Cams grinds most of these cams 4 degrees advanced.
I check my cam centerline. It is 102 degrees. The cam card says the cam centerline is 106 degrees. Since this is 4 degrees advanced, is this right? Or should it be right at 106?
I have run out of time tonight. Tomorrow I plan on verifying that I have TDC exactly right and basically repeat the whole procedure.
Rod
Rod
