purplebeast
As I have posted here before, I'm building up the 273 in my Dart. I'm going with a Comp Cams XE 256H. My question is: is it worth the trouble to degree the cam on a street motor? I'm using a true roller timing chain, which should be more accurate than the stock setup w/nylon gears. Any thoughts? Thanks.
