Denso mini starter (Dodge Ram)
Electrical and Ignition
  1. OnEbAd340
    OnEbAd340 Well-Known Member
    76
    22
    Mar 19, 2006
    RI
    Local Time:
    12:10 PM
    I don't know if this is useful or not. I ordered a 99' Ram 5.9 starter for my 340, when I got it I thought I would be able to get the female connector for the chassis side. After learning Mopar does not list it or carry it anymore and not wanting to crawl under a car/ truck at the junkyard, I did some searching on the internet. I learned that you can buy stud solenoid terminals as the Starter is a Denso OSGR and they came in many different styles across the different vehicles they fit.
    I ordered :
    76-82572 Terminal solenoid $2.16
    66-82404 Gasket for solenoid $1.24
    72-82100 Cover for leads $1.56 20200516_164411.jpg 20200516_164415.jpg 20200516_164422.jpg
    • Like Like x 2
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      43,004
      10585
      Oct 14, 2010
      Idaho
      Local Time:
      10:10 AM
      OK you lost me here. I do know that some of these starters are different, but what did you start with that you ended up with this? Are you sayin that the starter came with a push on connector?
    • OnEbAd340
      76
      22
      Mar 19, 2006
      RI
      Local Time:
      12:10 PM
      Yes, came with the weather tight male connector( Delphi type). I looked and could not find the Female connector anywhere for it. I also checked Dodge and Jeep and the part is NLA and does not supersede. 20200513_204915.jpg 20200514_114212.jpg
      • Thanks! Thanks! x 1
      • 67Dart273
        43,004
        10585
        Oct 14, 2010
        Idaho
        Local Time:
        10:10 AM
        OH very good!!! Goin' to have to (try) and remember this!!
      • pomonamissel
        pomonamissel Well-Known Member
        1,840
        882
        May 21, 2015
        san jose , ca
        Local Time:
        12:10 PM
        bought some adapters from a member here that pulls those out to the outside a bit . still should cut the stud a bit , it sits in the soft plug area on my b's n rb's . for great starts the ground cable goes to the starter mounting as well . DSC00817.JPG
      • mopowers
        mopowers Well-Known Member
        4,729
        1849
        Feb 15, 2006
        West Sacramento, CA
        Local Time:
        10:10 AM
        This is good to know! Where did you buy the parts? Do the regular autoparts stores carry those?
      • OnEbAd340
        76
        22
        Mar 19, 2006
        RI
        Local Time:
        12:10 PM
        • Thanks! Thanks! x 2
        • dartfreak75
          dartfreak75 Restore it, Dont part it! FABO Gold Member
          7,481
          5237
          Aug 10, 2011
          Virginia
          Local Time:
          1:10 PM
          Very cool thanks for sharing
