stumblinhorse
Due to bad life choices my stroker build is out the window. So going standard rebuild on my 318. I am trying to figure CR with the KB399 dome pistons .030 over. My J heads measure to around 71-72 CC, they are the 2.02 variety. Using MP head gaskets .028 thick 4.06 bore.
the KB399 are .140 dome, how do you take that into the consideration with a CR calculator?
Trying to keep my SCR pretty high, since my DCR will be way low at my elevation (7000ft)
Thanks for the help.
