Diablosport cracked code- years?
cu440da
Cottage Grove, MN
What model years did the complete cracking of coding start?
I was planning on using Megasquirt, but now am considering a factory computer. Now that Mopar has seen the light and helped Diablosport unlock the coding it seems like picking up a complete motor with wiring harness and computer makes more sense. But only if the torque management can be COMPLETELY disabled.
I am looking at a 2013 truck motor, coupling it with a Viper T56. Can these newer computers be flashed for use with a manual transmission?
Any opinions either way?
I know I can change the parameters on my 2011 392. I believe they have the ability to tune through 2013. 2012 for sure.
The engine year is not the problem to tune it is the ECU.
If you are looking to do a New Gen swap DO NOT GET THE ECU THAT CAME WITH THE CAR IT WILL NOT WORK! We do offer a Mopar ECU that does and can be custom flashed and tuned for whatever you need it to do so please give us a call we will get you in the right direction.
