diagram of 69 B'cuda fastback interior pieces
str12-340
Vashon, WA
I'm helping a friend reassemble a 1969 Barracuda fastback. The interior (yeah that really complicated completely trimmed out folding back seat and 'trunk') was completely disassembled and piled in the trunk. The car came with a complete carpet kit. The thing is complicated enough that it isn't obvious how the whole thing goes together. He has the two book FSM and a factory assembly manual, but neither show how all this works. Does anybody have a diagram or pics from taking theirs apart and/or putting it back together? I figured out the wheel well covers and wide trim around the inside of the back window, and the piece with the "dome lights" that start at the base of the side windows, but the folding seat and underlying floor we just can't figure out. There's a piece of plywood, a metal sheet with a 90 degree extension, hinges and stainless plates, latch mechanisms... Yeesh.
90 degree sheet metal piece is the floor behind the rear seat . The plywood is the folding panel that separates the trunk from the interior and goes right behind the sheet metal piece . The latch goes on the plywood to hold it closed when upright .
Thank you! any chance of a few pictures?
1/2" plywood sheet is the cargo/ trunk divider. It would have a long piano hinge on the bottom and 2 slam latches on top. The leg of the steel floor panel installs with the leg towards the front of car. The plywood with piano hinge attaches to the rear of that floor sheet, and folds down into the trunk area. A SS angle screws to the front edge of the steel cargo floor piece and holds the carpet on.
