Did the 65 6 cyl have a radiator shroud
I have a 65 Dart V-8 and a 64 Valiant slant. Neither had a shroud when I got them, but don't know original status. I put a plastic shroud on my 65 that fit perfect on the ~72 new radiator I got, which I think might have been for a slant w/ AC.
The 65 A bodies could have come with a shroud, and it would be a 2 piece metal unit. They are pretty hard to find, and IMO the 6 cylinder model is more scarce than the V8 unit, although cheaper to buy!! Geof
To answer the OP's original question, whether or not a car had a fan shroud would depend on whether or not the car had HD cooling. HD cooling was mandatory with factory A/C and the towing package. It was also available separately.
Neither the V-8 nor /6 shrouds is symetrical with the radiator. I can not confirm this but have heard that the V-8 shroud will work on the /6 if it is rotated 180 degrees.
