RDJ
I'm curious what the difference is between the Edelbock RPM Air-Gap (7576) and the Edelbrock Performer RPM (7176). They are both dual plane rated at 1,500-6,500 rpms.
Which one is better for my build, and, is one taller than the other with the potential to not be able to close my hood? 1967 Barracuda.
Planned engine 360 LA block, 408 stroker, Edelbrock heads, Hughes 232/237 @0.50, 540/548 lift 110 lobe cam, 10.3 compression, TTI headers, 3.23 sure grip, 2800 stall converter.
A little history, I was originally planning to do a stockish budget build with some Magnum heads I have, so I bought a Professional Products Crosswind intake (rpm-airgap copy intake), because the Edelbrock Magnum rpm intake was about $400 and the Crosswind was only $180.
But, after much reflection, I am going full on with the engine. Now that I am going with the LA style Eddie heads, the Edelbrock intakes are $225-$260 (depending on which model). Not much more than the Crosswind when you take into account the amount I am spending.
First of all, I have read mixed reviews of the Crosswind. Some say it is fine, no problems, and just like an Eddie RPM. Other reviews say they are not the best quaility and the real Eddie RPM works much better.
So, is is worth the extra $$ for the real Eddie RPM, or would the Performer RPM be better anyway?
