Digital or Analog tachometer.
MileHighDart
Lakeview, OR
What would you choose, and why.
Either way I go it will be mounted on top, or top side of steering column so it will be easily visible when driving. Right now I have an old analog mounted on the front end of my console, looks neat, but not very easy to look at without taking your eyes off the road.
analog... Your brain has to process number and correlate them.
Analog only takes a glance.
Analog can be read with your peripheral vision. Not so with a digital. I absolutely HATED the digital speedo on my 2002 Triumph Daytona 955. The tach was analog and easy to catch but not so the speedo.
Analog, I have an Auto Meter Monster Tach with Shift Light, the
tach is mounted below the dash under the ashtray and I got the light extension cord so I could mount the Shift Light on the Steering Column, it doesn't block any gauges or lights, but gets my attention enough to shift when I wind it up to 5800 RPM without even looking at it.
I never look at the tach. I can hear the engine and feel her pull or fall off.
In fact the only time I look at the tach is in replay mode. The only gauges I look at while normal driving are H2o temp, Oil pressure. Sometimes volts.
My shift light is mounted on the front A pillar cage bar and shines right in my peripheral. By the time it's on I've already fu@ked up
You can see my gauges are layed out in order of importance. MPH, and tach are behind the steering wheel cuz I never look at them.
AFR, OIL PSI, H2O TEMP, MPH, TACH, FUEL, VOLTS, VAC. FUEL PSI on cowl.
I prefer analog over digital...
With digital, you only see the number change...
With analog, you can see how fast the needle changes/moves to get a better feel for what's going on...
My AFR gauge is both digital and "analog." While the data logging is nice I cant watch the numbers flash as easy as I can watch the bar move.
The numbers just move to fast for my brain while the analog part is a nice easy sweep.
