metallidart
member me?
I bought one of the last sets he made, and I have no complaints about the quality, although I have yet to drive on them. I do, however, have a question, andits been nagging me for months.
I bought them with the poly bushings, which were Prothane, and had no outer shell. When you put them in the arm, it is a loose fit-actually, some play-and when I asked him, he noticed it as well, and said Prothane said they were for the measurements he had, and so far no problems.
How many of you have these arms, with the prothane bushings? I am kind of thinking that the arms need the press-fit type, with the outer sleeve already installed, similar to the stock replacement. I just havent had the chance to check.
If that is the case, I will use the Prothane in the stock arms in my 68 and use the MP poly bushings with the outer sleeves in my Dillinger arms.
