340sFastback
I got the plain steel dip stick tube from Mancini Racing. I filed the end a little bit and then put it in the freezer for an hour. Sprayed some WD40 in the hole. Then I used a bunch of sockets (as in 3/8" socket wrench) and stacked them all the way up the tube with a small socket down by the bottom where the lip is. Tapped it right in no problem. Then I wedged a socket between the block and dip stick down low and pushed the tube in to clear the fuel pump. Worked great.
