SS Lancer
Yes sir !!Cool stuff for sure. It’s just money under the bridge I like to say!
Build what u like and enjoy
That old Dirt Nap is coming for us all
Enjoy everyday indeed.
I like how u think it will certainly make some nice ( Ear **** ) up above 7500 !Correct! While the numbers aren't huge (about the same as properly worked J heads), they fit the class requirements well and allow enough of a weight break to put the car in the middle of the field. They should still feed 321 inches with a 1.94:1 rod ratio to just shy of 8000 rpm.
There is always a way to make more money....Cool stuff for sure. It’s just money under the bridge I like to say!
Yes sir - im good at spending moneyThere is always a way to make more money....
I’ll spend it just the same...
Yes sir money can be had if one desires it .There is always a way to make more money....
Thank you keep in mind my model heads are simply 1975 smoger castings that were ported at Mullen and company !!!!
They are 5 years after the TA heads were campaigned and 1 year before the W2 was revealed my castings are mentioned as
(W1) in several 1975 publications.
Mullen offered a heavily modified (360 casting - same as mine but special welding needed etc for Pro-Stock class I wish I had some of those and my numbers would be more impressive nevertheless for class I want to race in these will work until I desire something else. I have a alot of money in these and many will question my direction versus other routes but These heads are Super rare to me and im honored to have um .
He did the Rpm intake and its beautiful ! All his work is exceptionalNevemind, I think you just answered my porting question. lol
Yes sirYeah, Jerry ain't nuthin but badass.
3 or 4.monthsWhat’s the time frame til it’s up and running?
Thanks for posting the flow sheet
So if I miss something here tell me what post that I can find it, my question is why so much lift on a style of head that typically begins to stall around 550 or so, I realize it will get to maximum flow quicker but it seems extreme to me. It seems like an extreme amount of spring pressure to accommodate questionable gain?
Okay that all is legit but at what point is beating the hell out of the valve train for questionable gain? I'm asking because I don't know I just like things to last. Maximum performance for a few hard runs is not an approach that I would take.I’ve answered this before but I’ll do it again. You can make almost any port back up on a flow bench. Especially with the intake manifold not on the head when it’s flowed.
So let’s say at .450 lift you are flowing...I’ll pull a number out of my hat...220 CFM and at .500 you are flowing 205 and it stays there. If we assume that the port is actually backing up while it’s running with the intake manifold on, if you lift average you’ll see that more lift still gives a higher average. And that matters.
Like compression ratio, most guys don’t use enough lift. Just because a head does something at a certain lift at a certain test pressure doesn’t mean it actually does that when it’s running.
This engine is for a Vintage Super Stock class also and not a street vessel !Okay that all is legit but at what point is beating the hell out of the valve train for questionable gain? I'm asking because I don't know I just like things to last. Maximum performance for a few hard runs is not an approach that I would take.
This information confirm my knowledge type of casting or design it is very strong at low lift numbers and benefit from more duration. I realizing compression is a consideration but it would help you extend the RPM range while decreasing un desirable angles and possibly unstable valve train. If we were talking about Apache heads or ls'cathedrals I would say yes and jam those valves to the Moon but we're not? 6,500 or 7,000 is one thing 8,500 or more it's night and day.I’m saying (and MO a explained it in more depth than I’m going to do here) is that you leave way more on the table than you think by using low lift.
As for hard on the valve train...that’s crazy. It’s 2021. The springs are better than ever. So are pushrods. And anyone with a smattering of gumption can correct their rocker geometry, which is where most valve train failures happen.
The GM guys are running .750 lift on the street and do it very reliably. Why should the Chrysler guys not benefit from higher lifts? You let the port do the work. You can run less seat timing, keep the same @.200 timing and make more power.
It’s the same with RPM. Chrysler guys are stuck at 6000 or maybe 6500. With a good oil pan and some careful prep work 7500 is easily doable. And that’s more horsepower. The gain from 6500 to 7000 is pretty good. You can also use a bit more gear with RPM and a loser converter, which BTW converter technology has gone through the roof.
So when you start adding up the gains from more lift, some RPM, gear and converter you are talking about some really big improvements.
For some, the minimal effort isn’t worth it. For me, it always is because the few extra dollars spent upfront pays big dividends in the end.
Chryslers do great without monster lifts for the very reasons you stated... thats why they can dominate stock class racing.This information confirm my knowledge type of casting or design it is very strong at low lift numbers and benefit from more duration. I realizing compression is a consideration but it would help you extend the RPM range while decreasing un desirable angles and possibly unstable valve train. If we were talking about Apache heads or ls'cathedrals I would say yes and jam those valves to the Moon but we're not? 6,500 or 7,000 is one thing 8,500 or more it's night and day.
Was 2.02 originally and still 2.02 but lite weight 11/32 TF valves2.02 now
Yes basically hate to alter some of the Last true Chrysler speed parts like these so I will proceed with that fact in mind but if they need work I will spend the money and try to improve them in general flow numbers stock and after final assembly will be gathered seems to be a mystery about the flow numbers .
The Prostock versions with monster valves and some needed brazing would have maybe reached your expectations.I'm just going to say I really was hoping to see like... 300 CFM out of these things or something legendary.. from a legendary name , that's all.
I had high hopes that were crushed. Lol
I think i shed a tear when i saw the numbers, needed a hug.. lmao
