moparfanatic56
i am sure that this has been posted many times before but here it is again. I am looking for advise or recommendations or whether or not to add a booster. I am just changing the fronts to disc and leaving the back drums. I will be going to the 4.5 bolt pattern on both. I understand that i will need to change the master cylinder and proportioning valve to accommodate this change but not sure about the booster.
Part 2: The rear end is a 8.75 so when I change the axles to the larger bolt pattern will I be able to use the current brake set up less the drum which will need to be changed to the new bolt pattern or will i need to change everything.
Thanks in advance for any input on this.
