Disc brakes
tkoboat
Active Member
More questions. I have a 1969 Dart. Previous owner added front disc brakes. Two msyteries
Calipers are mounted on back side. Large ball joints and 4" bolt on one piece rotors. Can this be? Please help.
T
I mounted my 74 set up on my 69 dart on the back to make room because of the sway bar
Sounds like they used the BBP disks of 73+ cars. You can buy a setup new on ebay (pricey). You can swap spindles L & R, and some even use Aspen or B-body spindles. Probably one setup gives the most caster, which we need for radial tires. You want the upper ball joint as far aft from the lower ball joint (centers) as possible.
