Hi everyone, I need help with a couple of wiring issues. Firstly my turn signals work, but only partially. I replaced the flasher between the glovebox and the radio, so the turn signals on the grille and bumper work, but not the side markers. The dash indicator for the left turn signal also does not work, but I figured that is probably the bulb. Oddly, pushing the hazard light switch in does nothing, but if it's in and I flip the turn signal switch either up or down, both come on at once (but still not the side markers)...
Secondly, there are a couple of disconnected sockets and one disconnect wire that I've found. This plug dangling near the fuse box looks just like the one for the flasher. Is this a separate relay for the side markers, should I put another flasher on there?
These other plugs, I have no idea what they go to. There is also a loose wire (orange) coming out of an adjacent plug. Anybody know what these are for? Thanks.
