Disconnecting Headlights
1969VADart
Fredericksburg, VA
I have a rather dumb question. I am in the process of swapping out my old engine and forward light harness for one of the Evans wiring harnesses on my 69 Dart. My question is...is there any easy way to unplug the headlights so that I can pull the harness out of the front end or do I have to tear the grille assembly apart to get to the connectors? I looked from under the car and the top, but no obvious easy way stands out. Would greatly appreciate any ideas.
Should be able to pop the headlites out as if you were going to put new ones in, and unplug them like that. Now depending where the ground wires are for the front, that could be tricky
Nope, you'll have to go at it just as if you were replacing the bulbs. OK you could go into the wheel well with a hole saw through the back of the lamp house. I wouldn't.
