[SOLD] Disk Brakes For Rear
titan
FLORIDA/GEORGIA
All The Parts For A Rear Disk Conversion On Mopar 8.25 From Jeep Grand Cherokee.Basically A Direct Bolt-On, Just Have To enlarge Center Register Hole A Hair, And Fabricate A Attachment To Connect E-Brake Cable.(Very Simple). With A Little Ingenuity, Can Be Adapted To A 8.75 Rear Also. Parts Included Are-2 Caliper Brackets/Shields. 2 Calipers. 2 Rotors 2 Hoses All E-Brake Parts. $125.00 + SH. Located In Sebastian, FL
Lower Picture Of A Set On 1972 Duster
On The 8.25 it bolts right on except for the very minor enlarging of the center hole( a 5 minute inconvenience)
I Would Like To Add,In The Next Week, I Will Be Back To Shop Where I Will Give The Rotors A Light Cut On The Brake Lathe So They Will Be Ready To Install. Shipping Will Be From 32958 45lbs. Box is 13''x13''x13'' U.P.S. Tom
This should fit in a USPS flat rate box if I'm not mistaken which will cut down on shipping.
