Distribution block ports?
R3dplanet
Not a TCP firewall question. Heh.
I bought this distribution block from Inline tube:
1962-64 Mopar A B C-Body Dual-Reservoir Master Cylinder Conversion Distribution Block
But I have no idea which ports are which. No diagram came with the part. I sent a message to them but received no response. Nothing in the service manual. Looked around here and BBD and did an image search but came up with nothing. What a damn nuisance.
Blow some air in one port and see which ones it comes out of.
Dry fitting it together it's perfectly clear that the BLK241 does not fit. I'll return it and find a more appropriate distribution block. Even so, the steel lines require more bending to work. Ah well.
