Ironmike
Thought I'd try and contribute for a change instead of asking questions. Haven't seen this here, so here goes.
Noticed last year that even with my distrib locked at 33 degrees, timing would "flutter" a bit at times. No big deal but it kinda bugged me. An oldtimer told me about this trick and I HOPE it's ok to do...makes sense.
So in pic 1 you can see my distib is bolted down. Note position of the rotor.
Pic 2 is me putting a little up pressure on my intermediate gear. If you look close, the rotor has definitely moved a couple degrees.
Went to the hardware store and bought a 1/2 inch bushing. Slide it on the shaft and carefully install disrib. You can now tighten the set screw enough to slide out your distrib and lock it permanantly. No more up and down movement of the gear.
Pic 3 is the bushing and pic 4 is installed on my distrib. I MAY use a small punch to make absolutely sure that set screw doesn't fly out at 7000 RPM. That's a little scary...
Pretty interestd in what you guys think. Is it a yay or nay?
