SS Lancer
Good infoYou can get a 1/2 shaft collar arod $3 at the hardware store. Watch the set screw on them make sure it is lock tighted and really tight. Reason I wont use them doing distrib rebuilds.
I got some bushing stock from the welding shop that worked great. drill a hole and use the roll pin.You can get a 1/2 shaft collar arod $3 at the hardware store. Watch the set screw on them make sure it is lock tighted and really tight. Reason I wont use them doing distrib rebuilds.
ToolmanmikeI got some bushing stock from the welding shop that worked great. drill a hole and use the roll pin.
