I have a 3874876 here, electronic ign distributor as was used on Super 6 equipped vehicles from the factory. I actually have 2 of them. One is NOS and is in the original existing engine in my truck. Only has like 100 miles on it. It was suggested to replace the vac advance pod, as (I have not looked) I guess the original has an "11R" on the arm from the vac adv, and it was suggested that one with an "8.5R" would be better for use in a truck.
I have 2 NOS from back in the day "Niehoff" vac advance chambers here. Both "8.5R". I forget the PN, it's "AL....... something" as I remember.
anyway I'm wanting to go thru the more "used" one I have here and restore/rebuild it if nothing else, a spare for my truck. Or I may use this one and keep that NOS one for the spare.
I had bought the NOS one on Ebay a while back for a good price. and it was in its sealed original box from back in the day/ not yet sure if I'm gonna modify that one or not.
Besides the new VA cans, I have a couple sets of those springs that (I believe) I got from Halifaxhops, (whoever was selling them a month or so ago) and a couple of new aftermarket (don't remember if they are Niehoff, Standard or who) pickup plates for a /6.
Anyway I just got a new NOS distributor shaft/governor for the more used/worn out one today in the mail. PN 3755827. I've seen pix both ways as in coming "with" and "without" a new nylon gear. This one came "without".
I also have ONE Napa DG404 distributor gear from back in the day, METAL!!!! I have not been able to find another. I wish I could find the bronze version here, the only way I see those is from Aussie Land and shipping would be the killer there. I plan to use this metal distributor gear on this new shaft/governor when I assemble this distributor.
and I wish I could find at least 1 more metal one.
Anyway, I may wind up with a few questions along the way..... but the 1st one, is that this NOS shaft/governor ***'y is not drilled for the roll pin that holds the dist gear to the shaft. and no instruction sheet as I see some of them pictured on Ebay seem to come with.
How do I figure out where to drill the hole on the lower shaft to hold the distributor gear on? Shaft rotation wise does it matter where this hole is drilled, for the vac advance can to wind up in a good spot and not hit the block or chassis, once installed in the block?
Also, advance curve wise, etc will the needs there change, based on whether I use a factory, 4 pin Mopar ECU vs if I decide to use a 4 pin GM HEI module?
I wish I had access to a distributor machine I could play around on.
