DIY HEMI/Hemi Wiring My findings
tRILLWIZZARD
New Member
CA.
I have a 03 Ram that I swapped a 05 pcm into for tuning at the same time I also deleted the original fusebox abs airbag module etc.... this is a question for all you guys who have made these standalone any tips or input on ignition wires and such? a list of sensor grounds and 5-volt outs? anything I noticed Chasm... doesn't respond he had some files and a flash for hp tuners anyone has them it would be great
THANK YOU WILL ALSO POST ALL MY FINDINGS WHEN IM DONE
I downloaded what he had when he first made it available. Pm me an email and I will send to you. One of the files was corrupt and would not read.
"We" and by that I mean everybody interested, need a central place to post this stuff
Actually most everything he posted is on here ABOUT US
and these were the only files I got that were not corrupted on the htp files
2005 Ram 5.7 & Standard Or Non-Electronic Transmission
Disabled rear O2's
Disabled Ambient Air Temp
Disabled EGR
Disabled Evap System
Disabled Fuel Level Sensors
Disable Battery Temp
Disabled A/C Sensors
Disabled P/S Pressure Sensors
Disabled Cruise Control Malfuntion
Disabled "VIN Not Programmed"
Disabled "Odometer Not Programmed"
Disabled "SKIM"
Disable Catalyst Warning
Disabled ABS
Disabled BCM
Disabled Speed Limiter
Disabled Brake Switch
Disabled Transmission Control Module
Enabled Standard Transmission
and for electronic trans
2005 Ram 5.7 & 545RFE
Disabled rear O2's
Disabled EGR
Disabled "SKIM"
Disabled ABS
Disabled BCM
HERE YOU GO GUYS This tune is for an 03 Hemi Ram Swapped to an 05 PCM tuned by a Well Known tuner you need the given beta to use it (the latest one)
