[WANTED] Dizzy Spacer
Just dug in the tool box. Yep I have it, spacer only though! Send me a PM And pay for shipping and it is yours. I will never use it and likely had for over 30 years.
See the other post for Distributor adapter....
P3690275 no longer made. We all need one or two. :poke:
Mancini carries two different kits, one for Mopers and one for MSD distributors. But they are $65.00 HTH, Lefty71
check the height difference to prove its .500. I made one and I thought it was .500, ended up looking just like that.... I actually put 3 set screws in to secure adapter to distributor.
How would measure that! If I measure the outside collar it is .601 do not think it takes account for all.
not OD, measure the height from block face to distributor base face. (or how far spacer is sticking up) Im guessing .500
Story the last in MM
Measured again while not trying to hold the ipad for phots.
1204”
Aaah, measure from the step to the inner step where the distrubutor base sits....youll have to measure the height of the largest OD part and then subtract the depth of the distributor seat. So 2.00 is the hole in block size..OAL is not critical. Good stuff.....
The inside step is .552 on 1 and .554 thou high on the other 1 of mine. Not .500 like someone else posted. 69383S. Lay it flat with the small part on a table, open calipers about an inch, the tail sticking out the end is what u measure with, put it inside then slide the caliper down till it rests on the table and the caliper rests on the inside ledge. Kim
