Do I need to change the driveline?
68fastback
Moscow, Idaho
I am swaping from a A833 to a 727 in a 68 Barracuda. Do I need to shorten or lengthen the driveline? Also will the yoke from the A833 work on the 727?
Pic of yoke
I looked around a bit and it looks like they do, the yokes for sure, depending on trans length since there are a couple different tailshafts out there. But if the trans are same similar length you're good to go.
Tom
that's what I thought, thank you very much. I unfortunately did not measure the A833 before I traded it off.
