68383GTS
I have not been able to find 70-72 Dart front lower quarter patch panels. The area between the rear of door and in front of the back tire. Does anyone repo this? Or do you have to buy a whole side skin?
How well do the Goodmark side skins fit?I have not been able to find 70-72 Dart front lower quarter patch panels. The area between the rear of door and in front of the back tire. Does anyone repo this? Or do you have to buy a whole side skin?
If you can weld in a patch panel you can make your own patch panel. If it helps, find something similar and beat it into submission. Buy a stretcher, shrinker tool . Indispensable tool for fabbing patch panels. Make your own even if you have to weld the wheel opening lip to the flat panel. Its all kind of butchery at that point anyway. DO IT.I have not been able to find 70-72 Dart front lower quarter patch panels. The area between the rear of door and in front of the back tire. Does anyone repo this? Or do you have to buy a whole side skin?
Behind the wheel doesn't look all that promising either. I'm pretty sure you are in denial thinking the whole area around the wheel opening doesn't need replacement. If you have a mig welder, YOU CAN DO IT
I think they are all made in Taiwan. Rarely do they fit and finish like the originals. Its your only option.No denial here to do it right and never worry about it again. It needs behind and in front of the wheel.I was thinking side skins or 1/2 panels.Looks like Goodmark side skins are about as much ad AMD rear patches.
