dodge dart brake booster
dragracer501
Member
rifle
I was wondering on my 1969 dart how hard it is to remove the booter and just run a normal
master cylinder. because the booster is large and in the way and I don't need the boost
is there a kit I need or can I just bolt the master up to where the booster bolts to? any help is awesome
Yes, a 4-bolt manual MC for your car will bolt up. They normally come w/ the brake rod installed. If not, you must search for a manual rod. You could also use a 4-2 bolt adapter plate ($30 ebay) and use a later aluminum 2-bolt MC. Many would work. Some here use one for ~1988 Dodge truck. Look for 15/16"D bore or smaller.
Also, flush new fluid to all wheels. You need to do so every 4 yrs or so, unless you use DOT 5. Maybe longer if you live where there are mesas like your photo.
